Jeep Resource for Jeep Forum, Classifieds, JeepSpace, Reviews, Pictures, Blogs, Clubs, Groups, Videos, Wiki, Links, Events, Articles
Jeep Forum Jeep Classifieds JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
    Groups
JeepSpace - View Red Jeep Club's Messages
Back To Group
1 >
Jeep not Starting
08/01/2009 12:47 AM
MorgansRaiders
View MorgansRaiders's Gallery
1993 Jeep YJ 6 cyl Four Wheel Drive Manual 140000 miles
I just got my 1993 Jeep Wrangler YJ. It worked perfectly fine for about two weeks now, but every so often the battery would seem weak when starting up. Took awhile for it to roar to life.
Then this morning, i went to start it, and it just clicked. It didnt even try to turn over. I tried it several times then gave up. I charged the battery all afternoon so it was at 100%. still nothing. I then tried to jump it with another truck. Still
08/01/2009 9:15 PM
WJ_Renegade
The Real McCoy
View WJ_Renegade's Gallery
Check all terminals between the battery and the starter. It sounds like it could be a bad connection. Look for buildup of corrosion or rust on all the ring terminals, and check the engine ground strap. If the ground strap is bad, it would cause those symptoms.
Six In A Row Makes It Go - Red Jeep Club Member #323
.._______OOOO_
.//_//_||_\\____\\____
|7/ \_|__|/ \(Oo\lllll/oO)
._(o)_)=o=(o)_)==o)_)
08/02/2009 2:00 AM
MorgansRaiders
yea i thought it might be that too. but i cleaned the posts and connection and it still didnt work. i then got a good new starter and it didnt work. then took push started it and took it to autozone. bought a remote starter, started right up. i think the problem is the ignition switch. its located above the steering wheel, so its kind of a pain to replace. right now i just have the remote starter hooked up to my starter, then the wires are goin through the whole in the floor and is draped over the shifter. Good temparary fix til i get the chance to replace my ignition switch
08/02/2009 1:15 PM
WJ_Renegade
The Real McCoy
Oh, yeah. I forgot about the ignition switch. Well, sounds like you got it figured out. Good luck swapping the switch. Doesn't sound like much of a walk in the park.
.._______OOOO_
Back To Group
1 >
